Need help with ac after accumulator replacement
Warriorpluto
I replaced the accumulator in my 07 Yukon Denali. I got one from O'Reilly Auto. The Murray brand. After using a vacuum to drain the evacuate the system after replacing the part and charging I put two cans in and it was cold yesterday now today it's not cold anymore. The compressor cycles on and off every five seconds. I tried to put more in but the gauge reads in the red now with compressor on. With the compressor off the low side reads 25lbs but when I try to put more in it doesn't take anymore. Also the hot side line is cold and the accumulator doesn't even attempt to get cold like yesterday.
W
Warriorpluto
Was using cheap gauge from Walmart today to get reading. The reading yesterday using my friend REAL ac gauges it was at 45lbs on low side with compressor on.
W
Warriorpluto
Pulled the orifice out the other day and it's melted. How could this happen
radmann07
