need help with fluid amounts
BlueCollarTahoe
hey whats up everyone looking for heklp with fluid amounts for front diff, transfer case, and rear diff. I did this maybe 70k miles ago and the notebook i wrote down all the details in got wet. having a hard time finding proper amounts before i do the service. i have a AWD 2004 chevy Tahoe 5.3 V8 T VIN. trying to find out the proper amounts needed so i can order amsoil brand, there isnt alot of places to go pick it up if i order an amount smaller than i need. anyone know where i can find this information? i have a pic of RPO sticker too if it helps. 20171010_225531.jpg
BlueCollarTahoe
BlueCollarTahoe
Doesn't Amsoil have those specs on its site?
it does but it has different amounts for the type of differentials you have. i cant figure out which ones i got to match up with their info.
Sam Harris
Texas
also what gaskets would you guys reccomend for the diff?
Lube locker 100%
When I recently did my rear diff (8.6), I needed a lot more fluid than expected. However, I also added a different cover to it, to provide a girdle, so apparently this makes a significant difference. I also used Amsoil, and had to source a couple more quarts locally. I was able to find a guy about 5 miles away who had it.
Typically though, those numbers should be spot on. Of course, I’m someone who ALWAYS gets more than I expect to need. Why not have it just in case? Pretty sure it won’t go bad without refrigeration.
rockola1971
Indiana (formerly IL)
BlueCollarTahoe
BlueCollarTahoe
BlueCollarTahoe
BlueCollarTahoe
also i seen 80w some places and 75w others. what would yall reccomend for a hard driven city stop and go daily truck? 170k miles
BlueCollarTahoe
BlueCollarTahoe
Lube locker 100%
im about to google the lube locker, but this is my concern far as the amount. nobody sells amsoil here pretty much. i rather order more than i need and keep the rest but i need an idea of how much i need you know? theres only like 2 stores ive seen that carry amsoil in the entire county.
