LoHoe
- Joined
- Oct 29, 2012
- Posts
- 211
- Reaction score
- 3
I have a 2007 Tahoe. I started to have a squeal every morning when I started it up. Took it by the dealer and they told me to try to change the belt. I swapped it out with the best offered at Advance Auto Parts which didnt stop the squeaking. I then sprayed WD40 on the main tensioner pulley where the bearing is and it would stop. After a few weeks of spraying WD40 on the bearing every morning it stopped working so I went to Advance Auto Parts yesterday and purchased a whole new assembly. I installed it and when I started it up and the squealing was back so I popped the hood and sprayed WD40 on the bearing of this new pulley and it went away. Called Advance this morning to tell them that the new assembly is squealing too and they told me that now it may be something else causing the squealing but they will swap out the assembly with a new one for me just incase the one I bought yesterday is bad. Dont understand how it could be something else when I spray WD40 on the bearing on the pulley and the squealing goes away. Please can someone help me with this problem and tell me what should I do now. I would appreciate it
