need some info on gettin more out of my truck
SunlitComet
OBS Jedi-Do Good
unknown at this time.
CIA should actually be CAI or Cold air intake, PCM is Powertrain Control Module or engine/tranny computer.A CAI just involves changing you air intake assembly and ducting. PCM tuning involves evaluating variable about your vehicle systems and what you are looking to change to have your PCM reprogrammed.
96ProCompTahoe
IN
cai - cold air intake, sorry for the mispelling. pcm is the computer.
4.88's and procomp 35's (probably closer to 34's now haha)
Danny_Z56
Franklinville NY
I get around 15-16 mpg mixed driving.
If i get froggy with the throttle i get around 13-14mpg.
I'd say a good tune would help your mpg #'s.
A few things you could do to shed some weight are: If you don't go on long trips you could take out your spair tire and jack.Also if you don't use your A/C much you could delete the entire system.
A/C bypass pulley,
http://www.autozone.com/autozone/pa.../A-C-Compressor-Bypass-Pulley/_/N-jd17lZ91tb7
darin95yuk
darin95yuk
well thanks fellas!!! so how much does a tune cost to my computer and whats a good cold air intake? and where can i get it done? and with the lift kit my truck shifts wierd how can i have my shift points adjusted or can i? i like my 3.73s maybe i need 4.88s like 96s has?
retorq
Kingman AZ
I don't think Blackbear does 95s. 95s have chip in them tbichips.com is a good place to start.
darin95yuk
darin95yuk
is there a place to tune my 95? and is there a way to adjust my shift points? it only shifts wierd when im going up hill it will downshift to third then fourth then third and fourth i kind of have to feather the pedal to keep it in third all the way up the hill...
blueflamed03
Oklahoma
best place IMHO for your model year
http://fastchip.com/
raptorforme93
Tampa, Fl
Someone with more knowledge will chime in but I'm going to say you definitely need to regear with those 35s on there. That will give him more power and should help or fix his shifting issue while going uphill shouldn't it?
blueflamed03
Oklahoma
yes, with 35's Id at least do 4.56's, then the chip, which will change shift points, etc
