new amp and loc
sick1166
just put in a bigger amp and loc
Reels
What does it take to wire one of those bad boys in? Something a weekend warrior can do?
diesel rob
Where did you tap into for the LC2...Did you do the back speakers or the Sub???
Turbotoys
Minnesota
Looking good - I am actually building a sub and amp rack in my back windows right now - Probably going to finish it in the spring/summer - Its getting cold in MN.
Did you tie in the LC2 from the factory amp in the back above the jack or did you swipe it from the doors??
On a side note: I have the full wiring diagram in .PDF for the whole vehicle if anyone needs it.
ccapehartusarmyINF.(ret)
Gilbert AZ
I built my amp rack installed my two amps i started on a saterday morning and worked on it all day and spent sunday makin everything look neat and pretty
so if your good with electrical wiring and soldering its doable in a weekend
but if its yer first after market stereo youll probably be out in yer garage till 3 am monday morning cussing up a storm
Turbotoys
Minnesota
Show us some pics of the install!! :)
Bigmac18
I could really use that diagram as well? maybe post a link?
Thanks
Njoppy
