Solved. New fuel pump, hard start.
Mcneils10
Hello everyone.
New here. I recently bought a 09 yukon denali with a blown up 6.2, I rebuilt it and but it back in. Now I'm a month down the road and I had to replace the pump due to rust at the assembly. After I replaced it I still had about 3-5 gallons of fuel in the tank, I tried to start and it started but took a few seconds probably around 5-10 seconds of cranking before it fired. I filled it to a half tank no issues but still take a few seconds of cranking to start or I have to try to start it a few times before it will fire. Any one know what could be going on? I'm checking the pressure in the morning.
Definitely check the fuel pressure to verify it's in spec.
When it's warmed up and running do a quick cam-crank correlation (CASE) procedure with a capable scanner, especially if either sensor was changed. Might not be your issue but with changes to the engine it might be the cause.
M
Mcneils10
I'll talk to my brother who tunes cars about the correlation sensor. Thank you for the advice.
j91z28d1
was it an oem pump?
I put a napa pump in my 96 and it was hard starting after that. I believe it wasn't holding fuel pressure correctly when it was off. if I clicked the key forward and paused for a second for it to build pressure. it would fire off cleanly every time like normal, if I didn't it would crank a few seconds longer and stumble a bit after the flare and then clean up.
I've just seen that newer gm now with the push button start will activate the fuel pump for a few seconds when you open the door to prime the system before cranking. I found that interesting.
petethepug
Michael
SoCal
Welcome from SoCal. Nice pull on the L9H in the Denali. Pull the charcoal emission canister and verify it’s not spilling carbon pellets into the field system.
Only use OEM f/p or Bosch, preferably with the lifetime warranty. Best prices on rockauto and parts geek. Generic f/p can have you chasing ghosts, intermittent ones at that.
Check your crank position sensor. I learned the hard way they fail and cause hard starts without sending a code.
giarcg
