New hitch and rollpan
Justinyukon
Hi everyone. I'm putting a street scene hitch and rollpan on my 98 4 dr Yukon. Anybody done this and have some pictures. Also am I getting into to any surprises. I know the frame needs to be cut but I've heard that you need to cut the gas tank straps and remount in a different location. Any advice and pictures would be appreciated
BigDaddy13440
Rome, NY
There shouldn't be any need to move the tank, it's on the driver's side frame, not in the rear like the S-10 Blazers were.
I've got a rollpan on my '96, and yes, I did cut the frame, about as close to the body mounts as I could get, and had to angle the cuts back from top to bottom to clear the pan.
I've got a hitch on mine, but it's not a hidden hitch (behind the plate), nor is it one of the U-Haul brackets that drops down about 4" below the frame and sticks out past the rollpan. I didn't want that look, so I bought a section of 2 1/2" x 8" rectangular steel channel, and bolted it across the framerails, but about 6" back from the cuts. I then bolted (and welded) a receiver hitch to the steel. I've got an 8" drop ball mount, and it doesn't stick out past the rollpan, I got tired of bashing my shins on the old one I used to have.
BurbyRST
