New Jersey Lift Kit Installers
battledenali
New Jersey
Does anyone have a New Jersey installer that has installed a lift or leveling kit on a Magnetic Suspension Yukon or Tahoe?
I know it should be easy enough to do the level, but I want to know about the lift and maintaining the Magnetic Suspension.
DenaliBQ
i did the suspension max leveling kit on my 2016 Yukon Denali with no problems really any good mechanic can do that for you just order the kit as far as lifts which i wish they had i haven't seen anything that will work with our trucks yet just the pick up trucks
Matt_
Depending on where you're at there's OK4WD (northern) and Globex (southern). I do my own work but know lots of people that swear by both those shops, and will probably have Globex to my gears because I dont enjoy swapping gears (done it twice, and both times swore i'd pay next time).
battledenali
battledenali
New Jersey
Thanks gentleman I will give both a look at see who's closer I'm way up north in jersey. I can't wait to lift this Denali up.
01Konvict
Boats n Hoes
Raleigh/SML
You could build your own lift otherwise a few out there already built for Denali packages. I’m thinking of doing a cst 4” for the fronts with rough country shock extenders rear with a 2” coil spacer. Fts ride height rod spacers. That will give it a true 4” up front and 2” rear to match fronts. 33/22x12
davidmakey230
