New member here! 6.2 Tahoe diff Id help
62Towhoe
62Towhoe
BlackBear tunes are undetectable.
Ok, so at that weight, you'll of course be using Tow/Haul mode, if she's still hunting for gears, use M4, that's just about 2900 at 70 mph. 4th is maximum cooling so it's ok to run there all day long. 4.10s will deliver 2568 rpms in 5th at 70 mph. Should be plenty of torque.
thanks yeah i ran the numbers and they seem to match up with what you got. 3.73 didn't seem like enough change to bother the effort.
we sure blackbear is undetectable? commiefornia recently passed the tune sniffing law for smog and from what ive heard they look at the size of the file for your map and if the file size is changed at all it throws a flag. i could see how a piggyback style tune would bypass this but the blackbear is a re-flash.
anyone in ca passed smog this year with blackbear?
getting some pics together now for you all
62Towhoe
62Towhoe
The good thing about the 3.42s is that if you end up hurting the factory rear 8.6" axle, a similar year 9.5" 14bolt will bolt right up with no gear changes. I agree with the others try a tune first for sure!
i figured this had the 10 bolt the whole time until i started looking into gears so i took a closer look and low and behold she has 14 bolts on the diff cover! guess there are some gmt900 tahoes that came factory with a 9.5 after all.
62Towhoe
62Towhoe
Welcome to the forum. Pics please.
You don't want to see the interior. Its a family car lol. Pretty straight except the hit and run ding on fender and tailgate dent from my trailer spotter sleeping on the job.
Dantheman1540
Sugar Loaf Mountain
Whoa post a pic of that because I was under the impression that only 2wd 6.2 trucks came with the 9.5 you have a gem! Should serve you well for a long time
wjburken
Eastern Iowa
@Doubeleive? Don’t you have a Blackbear tune?
Cool car collection man, love the K5
Any GMT900 equipped with a 6.2 and can be RWD will have the 14-Bolt, that includes 4x4s so that includes the 6.2 Tahoes of 2008 and 2009 and the 2010 6.2 Yukon XL SLTs as well.
It would also include the 2007-2009 Suburbans and Yukon XLs equipped with the 6.0 L76 and almost forgot those 2010 Canadian Avalanches with the 6.2 as well.
3.73s are what the 2500s have and the NHT pick up trucks. This allows the 2500 Suburbans to tow over 9,000 pounds and for the NHT pickups to tow over 10,000 pounds. Your tires makes it necessary to go down to 4.10s for the same effect. My daughter's NHT has 3.73s but with 35s they're acting more like 3.42s. It'll get 4.10s or 4.30s someday.
I do use a BB tune, but I had a hiccup with a previous hypertech tune. short version is I had the transmission rebuilt and the hypertech would not program back to stock, so BB used the hypertech tune as my stock file, luckily the hypertech has a c.a.r.b. sticker, so I put the hypertech back on for smog and then put the BB tune back on afterwards, I did not try to smog it with the bb tune installed.
even if you got the bb tune you could just put it back to stock for smog and then put it back on, it does reset the sensors doing that so, always drive it a couple days first on the stock file before going to smog it.
05TahoeOperator
