New rear brakes, problems.
rolfsent
Cincinnati
Just got new drums and shoes installed on my 1999 Denali and they make a horrible screeching noise now. I took my truck to a different mechanic and had him check them out after he rechecked them and couldn't find any problems and the other mechanic said they look perfect and doesn't think there's anything wrong. What would cause them to make such a bad noise? They also feel like they shudder when rolling to a stop. Somebody help me on this, it's driving me nuts.
gpracer1
Phoenix
They could miss it if they are the type of tech that doesn't bother putting anti seize on there in the first place!
But it's hard to tell without hearing he sound in person.
rolfsent
rolfsent
Cincinnati
I'll record a clip today, it's an ear piercing screech
---------- Post added at 11:28 AM ---------- Previous post was at 11:04 AM ----------
I forgot to add, the brakes don't start making noise until about 5-10 minutes into driving. It's probably just heat I'm guessing.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
did you resurface your drums? better yet are you sure those are not the fronts rubbing the wear indicator. It sounds like something out of round.
rolfsent
rolfsent
Cincinnati
Drums got replaced with the shoes, I'm positive it's not coming from the front.
---------- Post added at 12:23 AM ---------- Previous post was at 12:21 AM ----------
Like I said I feel a shudder when rolling to a stop and it's definitely coming from the back the shudder will happen right as the car stops and last for 1 second at most.
SunlitComet
OBS Jedi-Do Good
I can only guess then that perhaps the linings are contaminated from grease or brake fluid perhaps or your drums did not fully seated against the axle flange. You are probably going to want to take the drums off to see what is happening.
patniven
