New Tahoe Owner...
AielloWilson
I just bought a 2002 tahoe with 83k miles. What can I expect as far as repair costs? What are the most common repairs for this generation Tahoe?
Thanks for the help...
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
2wd 4wd?
most common repair is the gauge cluster due to poorly designed stepper motors. Luckily you can DIY for $50 or less. that affects every single one, and yours is due.
A
AielloWilson
5.3 LS model....4wd.... 3 rows... factory everything... non-heated seats.. sunroof.
Bailey-Hoe!
Vermont
JK
Just messing with you. I am also a newer Tahoe owner and other than the simple things people have to fix...it is a great truck. I come from the Audi world and I am stoked to have a vehicle I can work on comfortably with one trip to the parts store.
Things you should do to feel better about
Oil/Filter change
Make sure your 4WD system is properly serviced
Make sure Tranny Fluid and lines are good
Plugs and Wires
Seafoam it! - breaks up carbon in motor.
Other issues you will see
Intermediate Steering Shaft. Search for it...there are several easy DIY fixes
REar Wiper Motor
Speed Wheel Sensors
* I list these becasue these are on my list of ToDo's...come spring/summer
Easy Mods
Black BEar Tune - more HP!
Corvette Servo - Crisp Shifts on Tranny
Depo Headlights
HID Upgrade from DDM Tuning
Its a great forum, very friendly. Ask around. Good luck.
BB
Thumper8302
OKC, OK
also guys dont forget the electronic brake control module.. (ecbm) im not sure if this problem effects the hoes or not but my 01 yukon's ecbm is out.. just thought i would prolly thro that out in the mix
Malden11b
