I hate to post yet another "what tire should I get" question, but here I am. I am looking for input regarding tire options for my 2005 Z71 Tahoe, bone stock. I have close to 50k miles on my current set of tires (Cooper Discoverer AT3 4S, standard load) and I'm just about to my wear indicators so I wanted to gauge for input on potentially changing brands, given my current needs. Unless advised otherwise I am looking at going up in size to the 285/70R17 instead of the 265s, mainly for aesthetics.
The tahoe is driven on pavement > 90% of the time, though I do sometimes venture out onto loose sand at the outer banks. Loose gravel roads are somewhat common, but not a whole lot of muddy terrain. I don't tow a lot, but if I do it's just an open trailer of yard waste to the dump. I will haul things in the back of the tahoe more than anything and I have definitely gotten closer to the max tire pressure rating than I'd like thanks to the tire's difficult (for me) to manage tire pressure --> even with performing the manual calculations to see what tire pressure my tahoe actually needs for each tire, I end up with underinflated tires, as evident by the cupping observed in the tread pattern. Going up another 5 psi or so gets me normal wear but also puts me closer to the end of tire pressure I don't want to be on.
So, in addition to answering the poll, I would like some input regarding the following questions:
1. How well do the Defenders hold up in loose sand? The outer banks access roads are typically full of the VERY dry loose packed sand (the kind that you sink over your feet if you walk on it). I air down and usually don't much issue with the Coopers but I have definitely slung some sand with them.
2. Are there any arguments against going up to the C or E load range?
3. How well do the Cooper AT3 LT tires hold up, relative to the AT3 or AT3 4S? I have seen a few hit or miss reviews for the LT rated tires.
My biggest needs for the new tires are:
1. Dry and Wet traction
2. Tread Life
3. Ability to handle the occasional non-paved roads
Thanks to everyone that responds via the poll and/or via comment.
2. Tread Life
