New to the group
ShreddinPow
Good day all!
I am new to the forum group and have to say that I am happy to have found it! A lot of good information that I have learned already..
However, with looking I haven't quite answered the question that I was looking for.
will 285/75/16s fit with only the t-bar adjustment and the rear blocking on stock rims?
as well, I am still a farily new yukon owner and have noticed not only mine, but a few others of age that I come across that seem to sit appx 1" lower in the rear end.. is that normal or is it weak leafs/shocks?
Definitely looking forward to being around for the awesome info from all! After reading the fuel pump whining thread I think I have found this weekends project!
Thanks again for your time and further knowledge!
Bigbody250
I have 315/75 on the stockers with a 3" body lift and it rubbed a lil on full lock... You'll have 2" of lift so you should be fine, if you get 1/2" spacers it probably won't rub at all
Freedom Motorsports
Welcome to the neighborhood!
Yess, they will fit, you may want to trim the inner fender liners where they will rub at full lock but they will fit. When you turn the bars up, leave about three threads on the bolts so as not to bottom them out, turning them up to gain height puts more stress on the springs and if you bottom them out and leave them you could cause premature failure and a rougher ride.
Meg_az19
