Ok guys, I've am trying to gather everything to lower the rear of my 2013 Suburban LT (No Auto Ride) and I would like to know what part numbers I need to get. I want to keep the stock shocks/struts to maintain as much of the factory ride as I can.
According to Belltech the 2" drop springs are p/n 23301 and the shock extenders are p/n 6651. I believe that's all I need for the actual drop but I also want to add in the Air Lift helper bags in the springs. Is there someone out there that can tell me what Air Lift bags I should get to fit the 2" drop springs from Belltech? Also, does anyone have a compressor setup that will work with the Air Lift bags that they recommend? This will likely be an addition at a later date, but I am trying to plan everything out.
I also intend to the the McGaughy's Strut Spacers to drop the front a little. I only plan to drop the front 1 or 2" max.
