No click from the clicker
fixxxer88
Last night i noticed that when i turn on any turn signal (to include the hazards) i wasnt getting any clicks from the clicker. All the lights were working inside and out. Is there a clicker module, if so anyone know where it is? or is it digital. Thanks in advance
73shark
KC, MO
Do the headlite on w/ key out chimes work? Do any sounds including radio work?
My 2007 lost all sounds when I started it to go to work and returned that nite. Happened once more in the three years I owned it.
F
fixxxer88
everything else is working as advertised. But it just started working again. Not sure why. Does anyone know if that is digital click or is there a clicker module?
73shark
KC, MO
It's created by the BCM. Comes out the driver side tweeter.
paradise
Almost everything in these trucks runs through the head unit. If something doesn't "sync" just right, you can have only some sounds, or no sounds at all. I had onetime that I didn't have any "key-in" chimes. Just pulling the key out and putting it back in , or turning the car off and on will reset things most of the time. Like Shark said, the sound comes through your front left speakers.
deangrell
Also note that the click stops if any other chime is active. It worried me the first time it happened, my seatbelt chime for my passenger was going off and i was turning and the click stopped until the chime was done.
DaisyGirl
