no fire
jdawg901
memphis tn.
my heater hose came loose at the quick release got water every where make a long story short got water in the distributer went ahead bought new one an rotor dont no what i did but started the hoe up got knockin from under cap so by the time i made to the key to turn off it cut off now it wont start and i get a lil smoke from tbi .
haks310
Got LEDs?
SoCal
Are you sure the distributor is sitting right and the timing is correct?
jdawg901
jdawg901
memphis tn.
everything was alright besides a little mis with the old one it got dark on me and lil fustrated will try in the morn u dont think i f**ed up the dist. oh my bad i meant i replaced the d cap not the whole dist.
haks310
Got LEDs?
SoCal
Hmm, what about the ignition module? Was that okay or did you replace it?
jdawg901
jdawg901
memphis tn.
thats fairly new maybe 6 months ,wires plugs cap rotor are new but imma put the old rotor back on it prob messed up when it was knockin in the cap
jdawg901
jdawg901
memphis tn.
found out this morn my dist. had moved the bolt that holds it in place was loose had to rotate until it was timed right.
bmead21
