NO sound!!!!!!!!!!!!!!!!!!!!!!!!!!! out of my new head unit
superman2
i have a 1998 yukon and a jensen vm9312 indash flipout.. i took out the fatory tape player and tryed to install my jensen. i get everything to come on but theres no sound comin out of the speekers. i get a lil pop sound when u turn the unit on and off but nothing else. if someone could help me that would be great.....pleaz i am soooooo sick of lisinig to the redio....ppl keep tellin me that there is a amp that i have to bypass but i am have never done one of this be4 so i am stuck.
D3NALI_99
same problem
i had the same problem... what you need to do is from the back of the jensen there is a blue and white wire which is called the remote wire... connect that to the pink wire from the smaller harness... that shoudl work.... hey where did you wire the pink and white wire that comes from the jensen head unit...??
raptorforme93
Tampa, Fl
Yea you have to hook up the remote turn on wire which tells the amp to turn on when the HU is powered on.
S
superman2
the pink wire is it on the wire harrnes i got from the store or is it the one that on the wire from the truck.......i dont have a pink and white wire on my jensen i have a all pink on which go to the brake but i put in on the ground
2K6TBSS
East Bay, CA
Are you using an adapter harness? If so, there should be 2 blue wires in the adapter harness. You need to hook both blue wires up to the blue wire that is coming out of the back of your deck.
S
superman2
thanks again to everyone that help me with this install but now i have a nother problem....its not that loud and the right side doesnt play as loud as the left....this is some crazy shit and this as to be the most hardest install i have every done....again can any one help me?
S
superman2
thanks anyway guys i got at workin right.......thanks again for everythng else
