Hello all,
I have a 2007 Denali with the 6.2L engine. Truck has 131K miles and has been serviced regularly (every 3k) for it's whole life. I do have the piston slap at warm up, but no bad sounds or other issue to speak of. No CEL or codes thrown...so I'm stumped.
When driving around town (stop and go), the truck operates fine. Even in the Phoenix heat, things are okay. Oil press at cruise is 35-37ish...and around 11 at idle. A little lower than normal, but nothing so bad that I'm freaking out. No knocking/pinging to speak of. However, the past 2 times I have driven on the highway for 25+ miles, the truck develops a noticeable ticking/pinging sound. No loss of oil pressure, no CEL. It does not sound like a rod/main issue...higher pitch than that. Also, the sound only exhibits during cruising efforts (steady 65-70mph). If I get off the throttle, the sound goes away. When I apply a reasonable amount of throttle, the sound goes away. Maintain that speed, it comes back.
Here's the weird part...when both times...when I got off the freeway and proceeded to drive stop and go, the sound went away. No change in temps in the engine/transmission (tranny was 201). I do have access to a Tech2, but honestly wouldn't know what I'm looking for.
Any ideas from anyone?????
