Norcal 3-5 drop and koko kuture Dacona
M3kanic
Looks good. Can't wait to see it lowered.
Sent from my SM-G900V using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
im looking at the pics and looks like they gave you the wrong offset. they make a 20mm which sticks out of the fenderwells and the 30mm which does not.
C
cambelsoop1
I ordered the 30
Sent from my SM-G935V using Tapatalk
C
cambelsoop1
The wheel stick out past the edge a lil bit. The face of the wheel which would be machined on the machined version is raised up a lil bit
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you can check the back of the rim make sure says 30 that front seems to stick out past the well. or you can check the backspacing.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
not the first time where 1 rim is 30mm and others 20mm or vise versa.
C
cambelsoop1
Nope all 30
ChubbyMessiah
