NORCAL SS Custom 2/3.5-4.5 for all 2wd 2015+ GM SUV
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Rear depemds on what springs gm used. Thereare 3 different rates used. Either wsy with spacer shpuld sit fine on xl or suburban. If ypu want to go full rear drop i would add in front drop struts
CMoore711
I have this kit with the front drop spindles rear end links/bump stop kit and will be installing soon on my ‘15 Yukon Denali XL 4WD. I’m after a 2”(1.75”)/3.5” drop. That being said how should I set up the rear? Use the 1” spacer keep OEM rubber spring isolators in or use the 5/8” heater hose?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
use spacer with the xl models
yukonchief
For you gurus........ how do I know if I have the auto ride shocks? I have a 2017 Yukon SLT with out tow package. Also which kit would get the rear leveled if not slightly higher in the back...... I just don’t want the front higher then the rear if you know what I mean.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if the rear has airlines to shocks you have autoride. My kit will be fine thats why rear is adjustable
yukonchief
Just checked and mine does not have air shocks..... so which kit do you offer for a 2017 Yukon to make it level or as close to level. I just don’t want the rear being lower then the front. Can you provide a link? Thanks
Screech
