Modified
- Joined
- Nov 15, 2019
- Posts
- 3
- Reaction score
- 5
If you are planning on going 4/6 with a Norcal_ss kit please be aware that there are several potential issues he will not tell you about.
On some models your axle will end up half an inch from your exhaust. Plan for that.
The sway bar has to be relocated and new holes drilled or else it will hit the panhard bar mount before it reaches the JDM links. Plan for that.
You need to cut a hole above the panhard bar mount on the axle to keep it from hitting as it is closer than the axle is to the frame. Plan for that.
You should cut off the bracket behind the upper control arm mount so you get even more clearance beyond the freetravel mod.
I went in blind. No warning from him on any of this. No instructions came with his kit. Which isn't even a kit. Its just a bunch of drop shipped parts from the manufactures. His "custom" springs might be legit, but I think they might just be Trailblazer drop springs from Belltech that he powdercoated black and slapped his name on. I may be wrong, but it seems like it.
All of this would be no issue if I had just been told what to expect so I didn't find out when it was too late to plan in advance for the work that really needs to be done.
When I pointed out these issues and asked for help he completely ghosted me and ignored my phone call. Literally hit ignore two rings in like a child. He does not support his product. I should have seen this coming after msging him back and forth before buying. It was like pulling teeth to get answers out of him. If I asked two questions in one msg he would only answer one. He was much more worried about getting paid.
I hope this post saves someone else the headache of dealing with Tony and helps them go into this with realistic expectations.
With that said, while it does ride OK, it does not drive like its stock. Thats a load of crap from a salesman. I went in assuming that was a lie anyways, as I have had tons of lowered trucks, so I'm not mad about that, but if you're expecting it to, don't. It rides fine, totally doable once everything is dealt with, but much rougher than stock.
Also, the Spohn Bars are overpriced crap. You don't need them to do it. They just push the axle back around a half inch overall to recenter and then come loose constantly and need to be readjusted. Another salesman pitch from Tony.
Do yourself a favor and just piece the kit together yourself. It will be cheaper anyways.
