Normal ticking???!!
A
Axm1096
IMO, that does sound like a lifter tick noise. But I have also seen here and heard here about driving 1000's of miles with no problems.
Is it odd that it only does it when the engine is up to temp is there any oil additive that would quite it down a bit
A
Axm1096
I am ok with the oil but have never been ok with Fram. IMO use AC Delco or Wix Premium. Several members have said they use Fram with no problems and that is their choice but I just have my preferences. Again, flex fuel or gas?
Its on premium gas its due for a oil change ill have to go with ac delco on the filter
A
Axm1096
So i believe i found what is the broken exhaust bolts that might be related to the ticking im talking about I've read that this might be the cause
TollKeeper
Brighton, CO
That will do it.. but usually its on cold starts, and then as the metal expands from heat, the ticking noise goes away..
wsteele
It is a very common issue, I agree you likely have found the source of the ticking noise.
Papaskip
