I just returned from our maiden trip with our spanking new 2017 Yukon SLE - a 2K mile trip through northern New England, southern Canada towing 5K lbs through maybe 3K foot elevation. I tried tow/haul mode on/off at 100 mile increments and found little difference in performance between on/off with the exception that tow/haul on reduced the gas mileage from 11 mpg to 10 mpg. My understanding is tow/haul will hold the gears a little longer which would explain the mpg reduction. I did not notice (via tachometer) any obvious gear toggling with tow/haul off even on reasonable up grades.
My questions -
* Is tow/haul needed mostly for heavier loads or longer/steeper grades than what I was doing or am I getting some other benefit that I'm not aware of?
* Is gear toggling, whether noticeable or not, more just annoying or does it cause excessive wear to the engine/transmission?
Thanks.
My questions -
Thanks.
