wildcatgoal
- Joined
- Mar 18, 2020
- Posts
- 140
- Reaction score
- 132
I am considering rebuilding my NP246 myself instead of buying a reman. The only thing holding me back is that you need a bloody $800 tool set to shim a new clutch pack properly. Un...be...leav...a...ble! It would be interesting to know if the shimming procedure is completely necessary - anyone know? Like, I'm not necessarily opposed to slight premature wear if I get unlucky, but I don't want the thing binding up.
Not one single reman company says that they are replacing the clutch packs on every unit. I got one of them to tell me that they do replace them IF they are out of spec (whatever that means).
This has me thinking, are the clutches in these (especially with very little 4WD use and literally never using Auto) something typically needing replacement? I don't have engagement issues with my t-case - it works great. But I do have at least 1 bad seal (rear output), 1 bad bearing (front output), and a play/clunk if I hand-rotate the drive shaft (which sounds like its coming from where the oil pump is more than anything).
Not replacing the clutches eliminates me having to either buy this ridiculously expensive tool or beg a transmission shop or dealer to shim the clutch pack for me, which adds time to the rebuild and downtime on the Tahoe. The entire rebuild kit with a reinforced rear case (which I don't actually NEED since my OEM one is not compromised), clutches, bearings, seals, etc. is almost $400. I can buy a remanufactured unit from what appears to be a reputable outfit for $700, but there's no guarantee the clutches were touched and they use black RTV which is NOT SUPPOSED TO BE USED ON THESE... arg. That's $300 to avoid spending time rebuilding, risking getting it wrong, annoyingly having to rent some tools from NAPA, etc.
What would y'all do here?
