Sorry Im new and couldn't find the info I need in a search... I have a 98 Tahoe with a bad 246 tcase I purchased a used 246 from a 99 Tahoe that was being parted out. The id plates match and they look the same except the output yoke from the 99 is just like a flat flange instead of the ujoint style that my 98 has I know the yokes slide out but wondering if anyone knows if the splines are the same?
Also the 99 shift motor only has the single plug with pigtail its likea 5 pole plug I think as the shift motor on my 98 has a 4 pole plug with pigtail but it also has a I think 6 pole plug that plugs directly into the motor... will the motor from my 98 fit the other case?
Thanks in advance for any input
