NVG149 Conversion
packle
I'm not sure where exactly to put this but this area seems to be mostly relevant? I have a NVG149 I want to use in a swap, however the vehicle I am swapping into is a passenger side drop. is it possible to convert a NVG149 to passenger drop? from my understanding you typically can do it because of the oiling system, but looking at teardowns you only need to relocate the oil pickup tube?
Geotrash
Dave
Richmond, VA
Maybe someone here will know differently, but AFAIK, it's not possible to convert it to passenger-side drop. Might be worth a call to offroaddesign.com to talk about options.
P
packle
Do you by chance know why its not possible at all? the bolt pattern looks to be symmetrical so clocking it 180 degrees shouldn't be a issue unless I'm looking at it wrong? I'm sure its not possible, but I just haven't been able to figure out why its not.
I'd much rather get a passenger drop as the OEM T-case is Pdrop and if that blows from 500+ HP then I can drop in the 149 and the only aftermarket front diff is also Pdrop, although I might be able to request a custom Driver side drop front diff but then I'd be forced to use the 149 from the start
walkerheartsfield
