I'm not up on my older ls open source tuning tools. when I had a 02 ls1 they hadn't cracked the obd2 emcs like they had the obd1 stuff. you were stuck with hpt or ls1 edit. both paid apps. now they have like 3 different flash tools for obd2. I think ls drod was just one of them.
my e38 ecm still isn't worth the hassle to the diy guys since the older ls ecms works just fine for swaps. so hpt it is for me too. I only use tuner pro for the old obd1 stuff currently.
sounds like that app with the extended pids probably only works with their dongle. unless they give you access to a list to type into torque app, (I'm still diging around the net for the rear air ride shock pressure pid myself, that and low side ac. other cheap dongles probably won't do much for you. is your obd2 port switched power? if not, you might want to make it so. that's a long time to leave stuff pluged in, most of the chips in them run on 3.3v and you're running a voltage drop circuit 24/7. plus powering sensitive electronic while cranking can have spikes and stuff, I'd wire it so it doesn't get power constantly and not during crank. Just key on.
what are you using tuner pro for? it actually warms my heart a bit to see the old 90s program still being used today
Who are you asking, me or the OP?
If me, the MX+ powers down after like 6-10 minutes after vehicle is shut off. I actually have a BT Dieselworks AutoSync dongle also, along with their OBD splitter cable, and keep the AutoSync hidden up under the dash and have the MX+ plugged into the other side which Replaces the OE OBD port under the dash.
I don't use Tuner Pro, but either OBDLink or Torque Pro.
My 95 mustang is OBD1 and I used a twEECer and software on a laptop to tune it. Can't think of the name at the moment, but I know I also used EEC Analyzer to analyzes logs and give recommendations. Moates Quarter horse keeps popping into my head though for some reason.
EDIT: just remembered the tuning software name is Binary Editor. Also, I did all this back in 2005ish and still have all the software and hardware installed but don't need to use it much unless I decide to change something up, lol
