Odd steering issue: Google-fu isn't helping
Fuelslt1
2003 Escalade AWD 6.0L 215k
My steering wheel will pull itself to the right (1/4 turn) when accelerating and recenter itself after reaching cruising speed or hitting a large bump.
During this time the truck continues to track straight.
This isn't torque steer as the truck does not pull to the right, only the steering wheel does.
Accelerating: Wheel is turned
Cruising: Wheel is straight
WHAT THE HELL IS GOING ON!?
3" front, 2" rear leveling kit (Installed 6 months ago)
New 33" BFG A/T's (Installed 6 months ago)
Recent alignment
Ball joints good
Steering position sensor unplugged, not a traction control/stability control issue (assuming)
Fuelslt1
Fuelslt1
Tightened the steering box by 1/4 turn, that didn't help.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I see that you have a few mods. Let's start with tire pressure. Is the right side lower than the left? This could create unwanted rolling resistance.
Secondly, how is your tread? Is the right side lower than the left by chance? Awd is finniky when it comes to uneven tires. Think of it like this. If you have a wagon that has lower tread on the right but you have a motor that tries to drive all the wheels at the same time, torque is going to go to the larger tire and make it want to steer towards the smaller tire.
Lastly the tires themselves could be causing the pull, though I tend to believe if it is a tire causing the pull, it would be pulling to the right constantly.
Try rotating front tires left and right. Does it still happen?
If so the angles of the drive shafts could be also contributing to the pull. Same theory as the smaller tire but in this case the shorter drive shaft.
ccapehartusarmyINF.(ret)
Gilbert AZ
need to check and see if you have excessive toe in or toe out
usually with awd or front wheel drive comes from the factory with a little toe out \ / to compensate for torque steer and what not
but if its turning the wheel a quarter turn yer toe alighnment is way out
Fuelslt1
Fuelslt1
I found the culprit. The tech that did my alignment recently forgot to tighten the upper A-arm bolts...on both sides.
dubyagee01
Tread Quarters in Summerville SC did the exact same thing to mine.
Suburbans
