odes, codes, and more codes
Dom
Hello all. A brief introduction: I recently bought a 2004 Suburban, 5.3L A code came up that both knock sensors were bad, so I replaced both, along with one harness (the other seemed to be in good shape, I cracked the plastic plug getting one out). Anyways, put everything back together, it has an obvious vacuum leak, you can hear it. I finally find a breather on the intake that the plug mysteriously has a hole in it, and replace the cap. Idle goes back to normal, engine light clears itself, problem seems to be solved. I drive it around for a day, engine light comes back on...they tell me there are several codes this time(I apologize, I didn't get the code numbers, I will go back and get the numbers if anyone is interested), but they all have to do with the engine running lean. "Bank 1-Lean", "Bank 2-Lean", etc. Is this the engines way of relearning fuel/air ratios, timing curve, etc? Is this something common? Any ideas where to start? A buddy thinks there is probably an EVAP leak, or that the fuel pressure might be low...not gonna pretend I have any idea how he came up with that conclusion, lol. Since I have limited tools at my disposal, I was gonna take it to a mechanic tomorrow for at least a diagnostic. I would prefer to save money and do the work myself, assuming I can figure out whats wrong with it. If you need specific questions answered, I can...just don't know what more to add. Other than the CEL it seems to be running perfectly fine, smooth idle, no noises, etc.
This is not my daily transportation, so I don't NEED it in some certain time frame, but I am getting incredibly frustrated with this, and would greatly appriciate any help you can offer. If I have found one thing from Internet forums, it is that whatever the problem, SOMEONE had the exact same problem before. Lol.
treehan77
TYF Fiend
Crestview, FL
likely Intake Manifold Gasket. mine's been fine so far (2005 model), but LOTS of people on here have had to replace this...Pretty sure tha's why my buddy's 2003 has the CEL light on. Its been on for literally years though and no problems, he just doesn't care i guess. Id have to fix it. Let other owners chime in, there's some really knowledgeable people on here, see what they say.
JamezDogg01
