OEM headlight question
Godfatherhoss
I want to buy OEM passenger and driver side headlamps for my 07 suburban. I went to gmparts direct and searched the GM part # 22853026 & 22853025. I get 2 results for each side both have the same GMpart # and are priced the same, the only difference is one is labeled as "headlamp assy" while the other is labeled as "Composite assy". But same part #. What is the difference of the two? Which ones should I buy? Thanks guys
yates ™
Resident Apple hater
Iowa
Can you post a link to what you're looking at.
G
Godfatherhoss
http://www.gmpartsdirect.co/auto-pa...cat/headlamp-components-****#&ui-state=dialog
cpederson
