oem panasonic flip down
jbryan76901
hey guys i have a problem if you could help it would help a bunch. my wife has a 05 yukon and we installed 4 headrest screens but she wants them to run off the flip down. if anyone knows the color code for the output side of the panasonic dvd player so i can tap into it. the model number of the player is 15200217. thanks a bunch for any help.
oak510_tahoe
Urban Assault
I posted this in the other thread but...
Maybe this can help if you can't find the connector ( this info was posted here sometime ago):
These are the pinouts for the GM Panasonic flip down DVD player found in most Escalades Denali's Tahoes and Suburbans
GM document ID# 1399571 and 1399582
On the 16 pin Connector
pin 1 YEL Battery Positive Voltage
pin 2 Tan Acc
pin 3 ORN Ident
pin 4 DK GRN Backlight Gound
pin 5 LT. BLU Video +
pin 6 DK BLU Ground
pin 7 BRN Audio Right
pin 8 PPL Audio Left
pin 9 WHT Backlight Batt+
pin 10 GRY Bus Data from Display
pin 11 RED Bus Data to Display
pin 12 BLK +5 Volts
pin 13 PINK Video
pin 14 BARE Video Shield
pin 15 BARE Audio Shield
pin 16 LT. GRN Audio Common
On the 12 pin Connector
pin 1 not used
pin 2 LTGRN/BLK VCM Class2 Serial Data (Data Link Connector)
pin 3 and 4 Not Used
pin 5 DK GRN/WHT Right Audio Signal
pin 6 BRN/WHT Left Audio Signal
pin 7 BLK/WHT Ground
pin 8 Not Used
pin 9 ORN Battery Voltage
pins 10 and 11 Not Used
pin 12 BLK/WHT Audio Common
The 8 pin Connector is Audio and Video inputs
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
you are gonna need to feed that output into a video amp, or better yet a switcher (which would include an amp).
Capeles
