off road lights
the big blue bus
richmond, va
i had wired my bumper lights and reverse lights without relay and they worked for a lil bit then blew the fuse. so i replaced fuse and wired in relay and now lights dont work. thr switch lights up and the relay clicks wehn i hit switch but no light. i tried to unhook cable from lights and connect to batter but it just sparked a lot. it worked yesturday that way. idk what is wrong. i really hate wiring. nothin ever works. i must be doing something wrong, only thing ever worked when i did was the cb. any help would be really appreicated thanks
96ProCompTahoe
IN
run a jumper from the battery to the lights positive wire, and ground out the other one. if it doesn't light you may have blown the bulbs with a short somewhere along the line.
the big blue bus
the big blue bus
richmond, va
i tried that pro comp and nothing and i got sparks at wire when touchin battery. it worked this way when i was first trying them out. i havent tried the back that way yet. i might take em apart and look at bulbs. i only go one spare bulb
the big blue bus
the big blue bus
richmond, va
i took back lights off and hookd to battery so they stil work... but when hookd to relay nothing happens. idk whats wrong
fyremanpat
Fyremanpat
is the relay clicking on and off when you put power to it? not to insult you but check your wiring one more time
96ProCompTahoe
IN
you may have a bad relay or its shorting out if you had it filled with mud.
+1 checking the wiring one more time. make sure you have a good ground on it as well
the big blue bus
the big blue bus
richmond, va
the lights workd and then stoped before i coverd it in mud. im going to look over it all friday and help my friend wire up his lights. the relay clicks when i turn switch on and off so im assuming it works?
backdoorbilly72
