Oil gauge has no reading
Hammer 82
I just bought a 2006 Yukon denali xl and the oil gauge shows no reading at all. Took into shop and they replaced the sending unit and changed the wiring harness. Would the next step be changing the whole instrument cluster ? Starting to get a little pricey
osiris94ej
Casper Wyoming
More than likely it's a stepper motor in the cluster since the pressure switch has been replaced. I would look at the data on a scan tool to see if it's showing pressure before jumping into the cluster.
Sent from my SM-N920V using Tapatalk
Cesar Valle
it is going to be your oil pressure sensor. i replaced my and the fixed the problem
tanguycryms
