Im actually from the New England area but currently in KS just cleaned the heck out of it for better view and isolation. Heres the oil puddle it is over time but the very wet part is newYou must be in California or someplace else warm - that thing is clean! +1 on checking the oil cooler block-off plate above the oil filter. Common leak spot.
Im actually from the New England area but currently in KS just cleaned the heck out of it for better view and isolation. Heres the oil puddle it is over time but the very wet part is newView attachment 426350
So I have a pretty good oil leak I have taken off the view cover and it looks dry any suggestions 07 yukon denali 6.2l AWDView attachment 426285View attachment 426286View attachment 426287View attachment 426288View attachment 426284estions?
Maybe not the rear main, but could be the rear cover which is common. In this case it won't likely sling off the flywheel, but can still drain down the back of the engine. This is very difficult to see.If it is the rear main it would be slinging off the front of the flywheel where you can't see. I have the same issue. Inside that inspection cover looks dry but the outside looks like hell. I am losing about 1/2-3/4 quarts a week. I plan on replacing the oil pan and gasket to see if it at least cuts that in half. I have already replaced the VLOM, VC gaskets and block off plate.
