I have a 2003 Tahoe with 5.3L with 162K miles, when I start it in the morning the oil pressure is around 40 psi but after it gets hot while driving the pressure will stay around 40 while driving and when i slow down it will drop till right over 20 psi. I know my truck has started leaking oil which i think its the rear main seal. May need to check the sending unit but i replaced that 2 years ago. Would the leak cause my pressure to be low? I run Pennzoil High Mileage 10W-30. Also while driving my truck makes a humming noise almost like off road tires make. I had the alignment checked because the front tires looked choppy on the inside and it was all good and everything was good and tight on the front end and tires rotated. I was told it could possibly be the shocks that need to be replaced which they do but would that cause the off road noise while driving? Any help would be appreciated. Thanks
