grimm
I've searched around the forums but I didn't find anything exactly like the issue I'm experiencing.
So within the last couple of days, I've noticed that my oil pressure gauge will drop to zero. However, under normal acceleration or steady speeds, I will get an average 40-60 lbs on the gauge, at a complete stop it will hover around 18 lbs. Sometimes heavy braking will dip it to zero, sometimes heavy acceleration will dip it to zero, and sometimes it's just random. I don't get any check engine light, or check gauges light (which I know both work).
So am I lookin at a potentially faulty gauge or relay? Does this happen when oil levels are below what they should be? Or am I going to have to prep myself to replace the oil pump.
Thoughts please. If you need more info I can try to provide some. Thanks
