Opinion needed on drop set up
Red_Raider
Derby, Kansas
Ok so Tony has a set of drop keys that he has for sale. I was thinking about buying those and Modded's 5" drop springs. Not sure how that would look though.
Alex33
should get you a nice 2/4 drop. I say go for it.
mharders
Just outside of Seattle
This is one that i posted on here before but here it is. 305/35/24 with keys and 5305 coils with stock autoride shocks.
285/45/22
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
In front keys will do 2 inches
In rear moddeds 5305 will do 4 but if its the old version will do 5 inches.
You will need deff shorter shocks for 4-5 inch drop
I would get the rear djm hardware kit and new bumpstops and also cut the rear bumpstop brackets off the frame so wont just be bottoming out axle to frame.
If you decide not to do the djm rear kit still will need to cut the brackets off the frame and add new pancake bumpstops to prevent axle hitting to frame which is $25 dollars.
Modded
That Guy
Looks at Max's truck to better understand how your setup will look. With 24s, you will have less fender gap than him also.
If you do not have Autoride, you will get at least a 4.5" of drop with the 5305s.
dylansmashed
