I have a 2005 suburban it has the overhead rear climate controls. Id like to install an overhead monitor and retain my climate controls. The only thing I've been able to find is a power acoustik 1502gm trim piece or mount that allows this. The main issue here is it is discontinued and hard to find and it only works with a discontinued monitor that is 15.1 inches which is pretty big. Due to the shape of the headliner I don't even know if this would work due to its size. Also I dropped the dome light/climate control down to look at what I was working with and there is a bunch of stuff it was covering up I assume I'd have to remove first.
Has anyone done a similar install, if so any help is appreciated.
