Thebesta94
Anyone on the forum do any overlanding in their tahoe? Looking to get into it, I'm located in texas so I'll have to drive out to new mexico most likely.. but just seeing if anyone out there is involved in that community?
The guys at Expedition Portal also have plenty of IFS trucks too. And if you don't think a Tahoe can do it then why does Expedition Portal have the folowing full size van on their front page doing it...
Wow, a lot to unpack in your posts but I'll address the most glaring flaws.
First of all using a Sportmobile (or similar) conversion to make the point that if a van can be used as an overland vehicle a Tahoe can is immensely misleading. Those vans are vans in look only, it takes a huge amount of modification and money to make them into capable 4x4 overland vehicles. https://sportsmobile.com/sportsmobile-4x4/. But yeah, I'm sure a 4" lift and 35s will do just as well.
In the van segment there isn't any other off the shelf solution, so if that's what you want that's the only way to go about it. In the SUV/Pickup segments however there are numerous other much better options as a starting platform so there's literally no reason to start with as poor a platform as a GMT suv and spend the money and energy to make it truly capable. Is it possible? Sure. Is it a good idea? No, that's in part why Expedition Portal and Mongolia aren't populated with Escalades.
Second, the fact that you happened to pull a Rubicon out of trouble once means literally zero. I've seen videos of granola box Subarus pulling very capable 4x4s out of places where they were stuck, it's called an outlier and not something to base a build decision on.
Last, overlanding capability isn't related to size, although obviously the smaller the wheelbase of the vehicle the more maneuverable it will be. But a person can make a Prospector XL into an overlander https://www.aev-conversions.com/vehicles/prospector-xl/. The issue with GMT SUVs isn't the size.
A true overlander has to be capable of handling a lot more than dirt roads and the occasional mud puddle so as to be prepared for most reasonable obstacles an unknown road in the middle of nowhere might put before you, even if one doesn't even encounter such an obstacle. Otherwise it's just a camping vehicle.
