Overseas Help
07whitehoe
LA aka Lower Alabama
I am currently stationed in Germany and have aquired a problem on my hoe. p2135 throttle pedal position sensor switch a/b voltage correlation. There are three lights that appear. Engine light with power reduced mode, service stabilitrak and service traction control. I looked at the wheel position sensor for the service stabilitrak & service traction control accompanying lights with the reduced engine power. Seem to be all ok. I have visual inspected lightly touched the TPS connector but have yet to try the loose wire test on the connector. I read something about checking the voltage drops on G103 & G104. My tahoe at an idle almost seems like it wants to turn off and the lights go dim and back to normal after the engine RPM drops. Any suggestions besides running this beeotch off a cliff or leave in czech!!!
SavageWarrior13
