Ox Locker in GMT900 with 3.42 gears?
strutaeng
Dallas, Texas
@strutaeng
That's an excellent video. Thoroughly informative yet not too long and drawn out. I've seen it before years ago but forgot how good it was. Looking into a TrueTrac at this point and possibly re-gearing to 3.73's.
I've heard/read many say that's a pointless re-gear - if you're gonna do it, might as well go up to at least a 4.10 - but I think for my application it'll be well worth it.
It's a 2wd DD that just needs a little traction enhancement and some more oomph for the local hills around town. 3.42's are pretty disappointing, I can't believe they're putting even more anemic gearing than that in many trucks today. 3.23's, 3.08's, etc.
There are a number of other ways they could improve MPG without robbing a truck's torque output.
Do you have the 4L or 6L transmission? What size tires?
I have 3.42s on my 99 Silverado I swapped a 5.3 into. I have an axle I regeared with 4.10 but haven't swapped it yet. My 06 Suburban 2500 has 4.10 and I really like them. But on the lighter 1500 Silverado, I think 3.73s would be a bit better for an all-around gear. This is with the 4L80e on my trucks though and around 31" tires? LT265/75/16
On the 6L you split the OD gears in two, so Abit better.
@strutaeng
3.73 is snappy enough and you won't loose much on highway drives if anything
07CLASSIC
Just installed a beefed-up 4L from Finish Line Trans, to replace the OEM 4L (Very happy with it.)
Roughly 32" on 20's.
Yeah, I'm hoping that's what the 3.73's will give me is a good all-around setup.
ETA: Especially with the addition of the TrueTrac.
strutaeng
Dallas, Texas
There was this guy on a different forum that had this old Chebby 1500 plow truck. He'd swapped a 14 bolt on the rear and the gear ratio didn't match the front. He only used it inside his property and exclusively for plowing, and he didn't want to mess with backlash, etc. So he ran some larger tractor rear tires and some tiny front tires. It was sketchy, but good enough for his use! LOL
I guess what I'm saying is another way to change the effective gear ratio is by running smaller or larger tires.
07CLASSIC
Interesting. My mind is struggling to understand the logic and dynamics of what he actually did, but I think it would only be right if we all had just enough land to be able to tinker like that all we wanted.
That'd be fun to be able to solve your own problems like that on your own land. So few today can even find enough room at their home to do basic maintenance on their vehicles. I loved working on my truck in the garage in recent years past and now Public Storage moved into our area and bought up all the storage companies and started sky-rocketing everyone's rents 3x/year.
Had to first consolidate two units into one and then ultimately move everything home. It's other fam members' belongings, I don't believe in storage units, but now my garage is filled and a guest room, etc. Wish I had more space. We all could use more.
it's just a matter of calculating the math of how many rotations one does versus the other
07CLASSIC
Right. My mind started down that road a ways, but I was trying to figure out how small tires on the front would ever cause the front and rear axles to turn at the same rate - then I 'membered he said the rear was a different ratio than the front and my ears started smoking just a little bit.
I guess I didn't have enough of the variables to put the whole picture together, but he did make it clear that his point was that changing the tire size is another way to change the gear ratio. Good point. I know that smaller tires/wheels also equal higher MPG, but not sure any of that would help my situation. :)
I think 33's are about as big as I could go without a lift and wheel well trimming, but I'm not sure that would help me create any extra torque. If it were that easy though, I'd possibly go that route.
strutaeng
Dallas, Texas
Yes, slightly higher RPM on the highway. But it also puts your cruising RPM where you engine is capable of making more power, so throttle response is better and the engine can maintain speed with less downshifting.
Yeah, that guy with the snowplow truck had like 3.42 originally, then swapped a 4.10 rear end. So you just play around with different combinations of OD of tires for the front and the back with those 2 different gear ratios until your RPMs or speeds are close enough using those online calculators.
Like this one:
DunzoDenali
