That will be nice. I have noticed that on the hwy hills.Yes, slightly higher RPM on the highway. Put it also put your cruising RPM where you engine is capable of making more power, so throttle response is better and the engine can maintain speed with less downshifting.
Ahh. Thank you. That'll be very useful and will sear some figures into my mental tables. Added to favorites list.Yeah, that guy with the snowplow truck had like 3.42 originally, then swapped a 4.10 rear end. So you just play around with different combinations of OD of tires for the front and the back with those 2 different gear ratios until your RPMs or speeds are close enough using those online calculators.
Like this one:
Spicer Transmission Ratio RPM Calculator
Use the Spicer Transmission Ratio RPM Calculator to determine your engine’s RPM based on the transmission gear ratio, tire height, MPH, and ring and pinion gear ratio.spicerparts.com
