oxygen sensor wire connections
crabbman
GYPSUM,COLORADO
Hello just installed two bosch oxygen sensors, forgot what item number, to the downstream taps.
While finishing job I plugged in main plug to sensor and it was not happening.. Spun the connection around 180 degrees and yes it went in nicely. Now a week later I have Service engine light on and AUTOZONE code reader says I have an electrical issue with this install.
Yesterday I went to the main connections and did DIELECTRIC GREASE. Also found another connector less than a ruler and also did DIELECTRIC GREASE. Also electric tape on other areas of main line.
I still have the error message.
Would a continuity tester be next or buy new main line plugs and re-due the wires?
Thank you.
I love auto mechanics gone wrong.
crabbman
crabbman
GYPSUM,COLORADO
Yes the main line connector is plugged in,just 180 degrees wrong. The release clips are 180 degrees from a normal clip in .
crabbman
crabbman
GYPSUM,COLORADO
does turning the main line socket 180 degrees effect the polarity even though it fits well into bosch o2 sensor?
01ssreda4
02s dont have polarity, they can be wired either way
nwalk7800
