P0102 + P0430 + P0420 Help!
saif najd
Hi
Iam getting all of this codes!!
And it seems that the code P0430 is hunting me today too it keeps coming on!!
I think the CC are empty!
So what do you think?
I am thinking on cleaning the O2 sensors and to use spacers to set it away from the direct exhause smoke flow
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Replace your cat assembly and your o2 sensors so that cats are treated well and monitored well too. Do not alter positioning of the sensors. And lastly clean up the MAF sensor with MAF cleaner spray. If it does not get rid of code later in a few days or it comes back after clearing it Nd there is no damaged wiring then replace it with a delco or Delphi unit only.
saif najd
saif najd
I agree but I don't want to replace the catalytic I want to cancel it completely I don't see the point of having such!
Why you don't recommend relocateing the o2 censors?
saif najd
saif najd
I found some info
General Motors Driving Cycle
A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes.To perform an OBDII Driving cycle do the following:Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.Reprinted on OBDII web site courtesy of General Motors Corporation© General Motors Corporation
---------- Post added at 06:19 AM ---------- Previous post was at 05:47 AM ----------
New found (will try)
Have you taken your cats off and now your Check Engine Lights on. Heres that fix you've been looking for. If you're running an off-road H-pipe or X-pipe, Screw-in MIL eliminators will shut off the annoying Check engine light and improve performance. A MIL (which is short for Malfunction Indicator Light) Eliminator Will Limit Exhaust Gas to the rear O2 sensors when running an off road mid-pipe or some mid or x pipes with ultra high-flow cats. Also these Mil Eliminators are adjustable to suit every need. FYI : The installation is straight forward and simple. Screw the MIL eliminator in to the existing exhaust bung where the rear O2 sensor normally attaches. Then Attach the oxygen sensor to the MIL Eliminator. Works great on ALL vehicles 1988 to 2013. These are also Fully Adjustable if Needed.
As I told before here where I am now even without the cats I can pass the emissions test and there is no law against it :)
BurbyRST
