P0300 & p0753
Hart
Did a code dump today, as that flashing SES light is Never a good sign, and I have a hunch these two might be related.
Haven't dug into it yet, but it has seemed to be running fine even when flashing. It does Stutter/jitter around the 5-20mph range, More "car in earthquake" than "engine not right" however.
I did recently Replace the gasket just after Catalytic converter, as it was shot and a half.
First step in my mind is to pull spark plugs, and ensure their Firing & not gummed up. Beyond that, I'm not quite sure where to go, so..
Is it possible/likely these two are related?
Any suggestions where to go after spark plugs, wire, and dist-cap?
Am I in over my head already?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You are having a tranny valving problem solve that and it may get rid of the misfire issue. It would be best to leave it to a tranny shop if you do not have the proper scanner.
4L60-E / 4L65-E Automatic Transmission
155722703
Diagnostic Chart (Part 1 Of 3)
86436922
Diagnostic Chart (Part 2 Of 3)
86436923
Diagnostic Chart (Part 3 Of 3)
86436924
Schematic
CIRCUIT DESCRIPTION
The 1-2 Shift Solenoid (SS) valve controls the fluid flow acting on the 1-2 and 3-4 shift valves. The solenoid is a normally-open exhaust valve. With the 2-3 SS valve, the 1-2 SS valve allows four different shifting combinations. The solenoid attaches to the control valve body within the transmission. The 1-2 SS valve receives ignition voltage through circuit 1020. The Vehicle Control Module (VCM) controls the solenoid by providing the ground path on circuit 1222.
When the VCM detects a continuous open, short to ground, or short to power in the 1-2 SS valve circuit, then DTC P0753 sets. DTC P0753 is a type A DTC.
CONDITIONS FOR RUNNING THE DTC
  • The system voltage is 10-19 volts.
  • The engine speed is greater than 450 RPM for 5 seconds .
  • The engine is not in fuel cutoff.
CONDITIONS FOR SETTING THE DTC
DTC P0753 sets if one of the following conditions occurs for 5 seconds:
Condition 1
The VCM commands the solenoid ON and the voltage feedback remains high (B+).
Condition 2
The VCM commands the solenoid OFF and the voltage feedback remains low (0 volts) .
ACTION TAKEN WHEN THE DTC SETS
  • The VCM illuminates the Malfunction Indicator Lamp (MIL) .
  • The VCM commands D2 line pressure.
  • The VCM inhibits 3-2 downshifts if the vehicle speed is greater than 48 km/h (30 mph) .
  • The VCM freezes shift adapts from being updated.
  • The VCM records the operating conditions when the Conditions for Setting the DTC are met. The VCM stores this information as Freeze Frame and Failure Records.
  • The VCM stores DTC P0753 in VCM history.
CONDITIONS FOR CLEARING THE MIL/DTC
  • The VCM turns OFF the MIL during the third consecutive trip in which the diagnostic lest runs and passes.
  • A scan tool can clear the MIL/DTC.
  • The VCM clears the DTC from VCM history if the vehicle completes 40 warm-up cycles without an emission-related diagnostic fault occurring.
  • The VCM cancels the DTC default actions when the fault no longer exists and/or the ignition switch is OFF long enough in order to power down the VCM.
DIAGNOSTIC AIDS
  • Inspect the wiring at the VCM, the transmission connector and all other circuit connecting points for the following conditions:
  • A backed out terminal
  • A damaged terminal
  • Reduced terminal tension
  • A chafed wire
  • A broken wire inside the insulation
  • Moisture intrusion
  • Corrosion
  • When diagnosing for an intermittent short or open condition, massage the wiring harness while watching the test equipment for a change.
  • Refer to the Shift Solenoid Valve State and Gear Ratio table.
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic table.
  1. This step tests the function of the 1-2 SS valve and the Automatic Transmission (AT) wiring harness assembly.
  2. This step tests for power to the 1-2 SS valve from the ignition through the fuse.
  3. This step tests the ability of the VCM and of the wiring to control the ground circuit.
  1. This step measures the resistance of the IAT wiring harness assembly and of the 1-2 SS valve.
---------- Post added at 02:32 PM ---------- Previous post was at 02:30 PM ----------
stock replacements should be Ac delco or Delphi.
Bdk0501
