Bedhead514
I've been getting a P0303 code on my 2003 Yukon (5.3L) for a few weeks now. The truck has approx. 148K miles.
Initially I thought it was the coil pack (spark plug and wire looked fine) so I swapped it out. The check engine light went off almost immediately and the car ran fine for about 48 hrs, then check engine light came back on with the P0303 code. After talking with a mechanic friend, he said the coil pack may be defective and recommended I take it back. I swapped out the coil pack for a new one, and just like before the code was gone and light went off. The truck ran fine for over a week this time, till again the check engine light came on and the P0303 came back (about 3 days ago).
Yesterday afternoon I put a new AC Delco spark plug (GM rec) in cylinder 3 and changed out the wire, no change with code still there. After that, I swapped the coil pack and wire for cylinders 3 and 4 to see if the problem would switch to cylinder 4. Unfortunately it didn’t, I now get a P0300 code.
Any idea what’s going on?
