vent canister purge valve through the code. replaced it but broke the clip on the hose didn't replace it yet. check engine light came back on..then
Ok so my service stability traction control light came on a few weeks ago never checked the check engine light to see if it through a code or not.
today engine was ticking bad and running really rough at idol. through some marvens into the engine and it stopped and smoothed out but had the engine light code ran and it was a p0305
problem is idk when it through the code! or which symptom made it throught the code.
also checked dipstick and why does the oil only stay on the side of the dip stick never all the way on it only up the side?
