totalpackage
- Joined
- Aug 28, 2015
- Posts
- 101
- Reaction score
- 12
Ive had the engine light intermittent for years due to this code. I changed all the o2 sensors and still had code popping up. I had a shop diagnoss the same issue and used there preference sensor. Still had the same issue. They stated it could be the PCM or shorted wire...What else is the main culprit on this code. The catalytic converter? Is the shop more correct?
I also ran across this link on here but not sure if i can check all functions.
http://ww2.justanswer.com/uploads/Bluegorilla/2009-10-20_142801_2001_k_P1153_delphi.pdf
