P1345 Camshaft Crankshaft Correlation
jamieeasley
Granbury, TX
Hey guys, I tried the search but it kept saying that nothing came up so I figured that I would just ask. I'm getting the code about the camshaft/crankshaft correlation, P1345 I think. Well the truck still runs fine, just feels a little down on power. I just got done replacing the lower intake manifold gaskets so I figured I must have gotten the distributor off a tooth. Moved it one tooth backward and forward and it ran much worse if at all. What else could be causing the problem? I've checked the sensors to both and they're both still plugged in and not loose. Any ideas what else it could be? Thanks for the help.
eod_tech
