p1345 code and engine light
1999hoe
aka HOVERHOE
Massachoochoosetts
Only noticable symptoms is on the highway a faint skip or jerk every now and again the engine light has been on a while idle isn't an issue exhaust smells a tad rich any ideas to the issue??? Thanks hoes
haks310
Got LEDs?
SoCal
You do intake gaskets recently?
Have you checked the timing?
badtothe bone
western pennsylvania
Your problem sounds like it is a crankshaft sensor / cam position sensor correlation error. In other words the sensor in your distributor that reports the position of the cam shaft and the crankshaft position sensor behind the harmonic balancer are not in sync. The most common cause is a distributor being removed and replaced a bit off.
Second would be wear of the distributor gear and third would be excessive slack/wear of the timing chain and gears. Or a bad sensor or wires from the sensor.
If you have had the distributor removed for any reason check it to see if it is at top dead center in relationship of #1 spark terminal and #1 cylinder..
If that is not the problem, check the distributor gear for wear.
You can test for wear by turning the distributor counter clockwise a degree or two and see if the code goes away. If this test is successful replace the gear soon as it also drives your oil pump!!
ravingmadman
Chief Knuckle Buster
Greater Seattle
You can also take it in for tune up. They be able to adjust the retard. I love saying that. By adjusting the retard, they'll be able to tell if your gears are worn, or not.
Black0460hhh
